grsabourin
Hi,
I would like to know if it is possible to adjust display sensitivity of the display of my S5. For example if I try to manage icon in my favourite tabs (removing an icon) I try to do a touch and hold to enter to edit mode drag the icon in the bin most of the time the application I would like to remove start instead of poping the edit mode. I'm not able to do the hold. Other example, very often with the key board I have multiple letters. It is like touch is detected twice. Are there ways to configure that
Thank you
Thank you
