Help Touch not working
hunzaboy
Hi Geeks!
i have samsung galaxy ace s5830 got 6 months ago. Worked perfectly till last week as suddenly the touch is not working.
Tried so far:
Recovery
Clear Partition
Even installed an updated verison of the software but no luck.
All physical buttons are working properly ( power, home , audio).
One more thing, when i factory reset it then the touch sometimes works perfectly. BUT as soon as i press the sleep ( power button ) , after that touch gets disabled.
ANY HELP PLEASE?
Sounds like you have tried all the things that I would have suggested. Might be time to take to service centre (and hope still under warranty) - Good luck
Look at the stickies for chismay's guide on how to go back to stock from cyanagenmod as it shows you how to find and flash a stock rom using Odin. If you do this you'll remove root and cwm also. Viola, warranty returned!
