touch screen middle portion is not working
It this case...only resetting the device might be able to fix this problem.
Hello and welcome aboard. You'll find your device support forum here HTC Wildfire - Android Forums.
If you aren't familiar on how to do a reset... Here's how: Tap menu - settings - storage - factory data reset. If this doesn't fix the problem then you might need to get the phone replaced.
