D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
1. Forum related questions.
2. Where is the Play Store app?
3. How can I improve the battery life of my Touchpad B1?
4. Are there any Touchpad B1 accessories??
5. Are there any Touchpad B1 Tips & Tricks?
6. What are the known problems with the Touchpad B1?
7. What is root?/What does being rooted mean?
Q: Where is the Play Store app?
A: Unfortunately, for some tablets, Google and/or the country that produced the tablet was manufactured in does not support official Google apps and you will not have access to the Play Store.
Q: How can I improve the battery life of my Touchpad B1?
A: Tablets operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/bluetooth/sync (amongst other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your tablet.
Here are a couple of things that you could consider - adjust the screen brightness, do not use live wallpapers, switch off networks when not in use (WIFI, Bluetooth, GPS), adjust update intervals for widgets (do you really need twitter/facebook notifications every half hour?). You could also consider downloading a battery monitoring app such as JuiceDefender.
Q: Are there any Touchpad B1 accessories?
A: For any tips, if you use the "filter by" and select "Accessories" in the sub-forum, you will get many useful tips and tricks.
Q: Are there any Touchpad B1 Tips & Tricks?
Q: What are some of the problems people have with their Touchpad B1?
A: Here is a post explaining that: What is rooted/doe s being rooted mean?
Here is a link to the http://androidforums.com/touchpad-b...pad-b1-all-things-root-guide.html#post3788615
