I have a Barnes & Noble Nook Tablet (acclaim) 16GB that I have flashed the latest CM 11 stable snapshot onto using ClockworkMod 6.0.5.1. I flashed it by creating a bootable SD card with CWM as directed by the CM Wiki, booted into it, cleared cache and dalvik cache, then flashed the .zip from the SD card. I did not install GApps or anything else, so it is a clean install.
Everything works fine until the battery gets low (around 15%), that's when the trouble begins. The screen will begin to behave very strangely, it will randomly tap, scroll, open apps, type jibberish on the keyboard, etc. and won't allow me to do anything other than hit the lock button. Once I charge it back up the issue goes away. This is not a hardware issue, being as this issue does not occur on the stock Barnes & Noble software. I've searched Google, forums, etc. but I haven't found anyone else who is having the same issue.
Any help would be appreciated.
logcat: http://pastebin.com/0RWxaHZZ
