touchscreen sensitivity
Bob dole
ok my hero's touchscreen isnt very sensitive, i will try to click somethign and it wont respond, like when i am dialing, it will work to good for some numbers, but other numbers refuse to work.
ok another question, does the battery being behind the lower section of the touchscreen while charging, which creates alot of heat from what i have noticed, affect the touchscreen? the top half of the screen that isnt above the battery works fine, but the lower half doesnt work at all while charging, when i first plugged in the phone to charge it worked abit to well,
