Hello,
I dropped my s3 in the toilet. I immediately removed it, took out the battery and put in rice for a few days. When i turned it on everything work, apart from the touchscreen does not respond all of the time. I took it apart and cleaned all of the points with alcohol, however it is still the same. Can anyone advise whether the issue is the motherboard or the digitizer, so i can replace, or could it be either?
Thanks
Thanks
