Help TouchWiz on S6
kps1422
Okay so when I go to end my programs the TouchWiz thingy pops up. Select Launcher.. it's always asking for either TouchWiz Home or TouchWiz easy home. And even if I press always it still comes up. WHY??? Is it a glitch?! I want it to stop. It didn't do that when I first got the phone but It started after I changed a theme then went back to the normal theme. It was a theme on the theme app that came with the phone.. I can't find a setting to stop the TouchWiz crap. Lol
Please help? Any ideas on how to stop it? Is this happening to anyone else?
Somehow your default launcher got cleared. Go to settings>applications>default applications>home. Select Touchwiz and is will be set as the default and stop prompting you to select a launcher.
Thank you so much! At first, for some odd reason.. it didn't work but then it worked. I think it was just a glitch. Again thank you so much!
I just tried this and it didn't work for me, I went back into the settings and tried it again and the default wasn't set again. How do I fix it?
You can try to clear the cache to see if that helps but other than that or a factory reset, I don't know what else could be done beyond reflashing the phone.
