mrhomiec
this is in regard to the message...
"To lower your risk of hearing damage, do not listen at high volumes for long periods."
for example, once you plug in headphones, TouchWiz will automatically set your media volume pretty low, and you would have to manually increase the media volume.
then if you unplug your headphones and immediately plug it back in, TouchWiz will again automatically lower the media volume.
with that in mind, i use my phone in my car via the AUX cable. because of this, i want the media volume all the way up so i could then use my car's volume setting. (my car also has bluetooth, but it only works for calls)
i have a Tasker profile that when it detects connection with my car's bluetooth, to set the volume to max.
however, if for some reason the bluetooth connection is lost later on, the media volume is then reverted to the low setting as if i just plugged into the headphone jack.
(or a specific case would be when i'm at home, i have another Tasker profile that if connected to Wi-Fi, to disable bluetooth. so when i'm in my driveway about to leave, or just coming home, bluetooth will turn off, and the media volume will lower)
i can't figure out why it does that.
it's not like the media volume is a toggle. once the media volume is set, it's set, right?
