razvan06
Hi everybody !
I like experimenting with my phones ,and the latest discovery is that when you get issues with your trackball [getting dirty and stuff] you can get a "Alcohol prep pad" ,dry it until it's just a bit moist and rub it against the "ball" for about 1 minute ,use a little pressure while doing it..
I noticed that after doing this every 3-4 weeks ,it runs smoother
JUST BE CAREFULL TO DRY IT !!! You are doing this at your own risk ,if it worked for me ,i can't say that it will work for you ! Don't let alcohol get inside at the circuits ,it will fry them !
Hope you find this useful .
