Apps Tracking location using GPS, WIFI or cell tower(HELP)
FunnehJM
Need help debugging my application. My GPS and WIFI can show lat, long and Accuracy.. why is my cell tower not showing anything? i have upload the source code..can you help me debug it for me?...
Java:
package com.example.nypindoormap;
import com.google.android.gms.common.ConnectionResult;
import com.google.android.gms.common.GooglePlayServicesUtil;
import com.google.android.gms.maps.GoogleMap;
import android.app.Dialog;
import android.content.Context;
import android.content.Intent;
import android.location.Location;
import android.location.LocationListener;
import android.location.LocationManager;
import android.os.Bundle;
import android.support.v4.app.FragmentActivity;
import android.telephony.TelephonyManager;
import android.telephony.gsm.GsmCellLocation;
import android.util.Log;
import android.view.Menu;
import android.view.MenuItem;
import android.view.View;
import android.view.View.OnClickListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.Toast;
public class MainActivity extends FragmentActivity {
    private static final int GPS_ERRORDIALOG_REQUEST = 9001;
    GoogleMap mMap;
    private static final String TAG = "D";
    //** declare Variables **
    // Create the authentication object
    // myAndroidContext must be a Context instance
    double wifiAcc;
    double gpsAcc;
    double nypAcc;
    double gpsLat;
    double gpsLng;
    double wifiLat;
    double wifiLng;
    double nypLat;
    double nypLng;
    double ActualDisplayLat;
    double ActualDisplayLng;
    double wifiDistanceActual;
    double gpsDistanceActual;
    double nypDistanceActual;
    double wifiDistanceGps;
    double gpsalt;
    double cellLat;
    double cellLng;
    double cellAcc;
    double cellDistanceActual;
    double cellalt;
    LocationManager locationManager;
    LocationListener gpsLocationListener;
    LocationListener wifiLocationListener;
    LocationListener cellLocationListener;
    LocationListener locationListener;
    EditText ActualDisplay;
    EditText GPS;
    EditText Wifi;
    EditText NYP;
    EditText cell;
    EditText level;
    Button map;
    Button mapBtn;
    String networkOperator;
    Boolean result;
    // variable to determine whether provider are connected.
    boolean gpsProvider = false;
    boolean wifiProvider = false;
    boolean cellProvider = false;
    @Override
        setContentView(R.layout.activity_main);
           //display view
    //** Find view of EditText *//*
        // for gps
        GPS = (EditText) findViewById(R.id.GPS);
         // for wifi
        Wifi = (EditText) findViewById(R.id.Wifi);
         // for nypculated
        NYP = (EditText) findViewById(R.id.NYP);
        cell = (EditText) findViewById(R.id.cell);
         // for location
        //ActualDisplay = (EditText) findViewById(R.id.ActualDisplay);
         // set Hardcoded actual location to text
         //ActualDisplayLat = 1.379524;
         //ActualDisplayLng = 103.848843;
         //String actualText = String.format("Desc:\t Block S level 4 \nLat:\t %f\nLong:\t %f", ActualDisplayLat, ActualDisplayLng);
         //ActualDisplay.setText(actualText);
     // ** Find view of button **
         // for check mapBTN
         map = (Button) findViewById(R.id.map);
         mapBtn = (Button) findViewById(R.id.map);
         map.setOnClickListener(new OnClickListener() {
             @Override
            public void onClick(View v) {
                // TODO Auto-generated method stub
                Intent intent = new Intent(MainActivity.this, MapActivity.class);
                startActivity(intent);
         mapBtn.setOnClickListener(new OnClickListener() {
            @Override
         // Acquire a reference to the system Location Manager for GPS and WIFI
         LocationManager locationManager = (LocationManager) this.getSystemService(Context.LOCATION_SERVICE);
         locationListener = new LocationListener() {
             @Override
            public void onLocationChanged(Location location) {
             // called when the listener is notified with a location update from the GPS
            // nypled when a new location is found by the network location provider.
              // Generate location based on provider
                 if(location.getProvider().contains("gps")) {
                      gpsNewLocation(location);
                 if(location.getProvider().contains("network")) {
                      wifiNewLocation(location);
                 if(location.getProvider().contains("cell")) {
                      cellNewLocation(location);
                 NYPNewLocation(gpsLat,gpsLng,gpsAcc,wifiLat,wifiLng,wifiAcc);
             @Override
            public void onStatusChanged(String provider, int status, Bundle extras) {}
             // called when the status of the GPS provider changes
             @Override
            public void onProviderEnabled(String provider) {}
             // called when the GPS provider is turned on (user turning on the GPS on the phone)
             @Override
            public void onProviderDisabled(String provider) {}
             // called when the GPS provider is turned off (user turning off the GPS on the phone)
         // Request Location
          locationManager.requestLocationUpdates(LocationManager.NETWORK_PROVIDER, 0, 0, locationListener);
          locationManager.requestLocationUpdates(LocationManager.GPS_PROVIDER, 0, 0, locationListener);
          setupMessageButton();
        private void setupMessageButton() {
            //1. get a reference to the button
            Button messageButton = (Button) findViewById(R.id.map);
            //2. Set the click listener to run my code.
            View.OnClickListener myListener = new View.OnClickListener() {
                private Location location;
                @Override
                    //creating a new intent
                    //Intent myIntent = new Intent(getApplicationContext(), MapActivity.class);
                    //startActivity(myIntent);
                    Intent intent= new Intent(MainActivity.this, MapActivity.class);
                     Bundle o = new Bundle();
                     o.putDouble("key",gpsalt);
                     intent.putExtras(o);
                    Log.i(TAG, "You clicked the button!");
                    Toast.makeText(MainActivity.this,
                            "You clicked map!",
                            Toast.LENGTH_LONG)
                    .show();
            messageButton.setOnClickListener(myListener);
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatinyply handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
public void startMap(View view) {
        startActivity(new Intent("com.example.MapActivity"));
        final Button button = (Button) findViewById(R.id.map);
        button.setOnClickListener(new View.OnClickListener() {
                // Perform action on click
                Intent activityChangeIntent = new Intent(MainActivity.this, MapActivity.class);
                // currentContext.startActivity(activityChangeIntent);
                MainActivity.this.startActivity(activityChangeIntent);
    public void gpsNewLocation(Location location) {
         Log.d(TAG, "onLocationChanged with location " + location.toString());
         gpsalt=location.getAltitude();
         gpsLat = location.getLatitude();
          gpsLng = location.getLongitude();
          gpsAcc = location.getAccuracy();
          // nypculate distance from actual
          double gpsActualLatPow = Math.pow((gpsLat - ActualDisplayLat), 2);
          double gpsActualLngPow = Math.pow((gpsLng - ActualDisplayLng), 2);
          double combineGpsPow = gpsActualLatPow + gpsActualLngPow;
          gpsDistanceActual =  Math.sqrt(combineGpsPow) * 1.1 * Math.pow(10,5);
         // if gps is provider
         String gpsText = String.format("Lat:\t %f\nLong:\t %f\nAlt:\t %f\nBearing:\t %f \nAccuracy:\t %f\nDistanceFromActual:\t %fm", location.getLatitude(), location.getLongitude(), location.getAltitude(), location.getBearing(), location.getAccuracy(),gpsDistanceActual);
         // Set Text
         GPS.setText(gpsText);
    protected void wifiNewLocation(Location location) {
        wifiLat = location.getLatitude();
         wifiLng = location.getLongitude();
         wifiAcc = location.getAccuracy();
         double wifiActualLatPow = Math.pow((wifiLat - ActualDisplayLat), 2);
         double wifiActualLngPow = Math.pow((wifiLng - ActualDisplayLng), 2);
         double combineWifiPow = wifiActualLatPow + wifiActualLngPow;
         wifiDistanceActual =  Math.sqrt(combineWifiPow) * 1.1 * Math.pow(10,5);
         // set string
        String wifiText = String.format("Lat:\t %f\nLong:\t %f\nAccuracy:\t %f\nDistanceFromActual:\t %fm", location.getLatitude(), location.getLongitude(), /*location.getAltitude()*/location.getAccuracy(), wifiDistanceActual);
        // Getting provider
        String provider = location.getProvider();
        // Set Text
        Wifi.setText(wifiText);
    protected void cellNewLocation(Location location) {
        // TelephonyManager telephonyManager = (TelephonyManager)getSystemService(Context.TELEPHONY_SERVICE);
         //GsmCellLocation cellLocation = (GsmCellLocation)telephonyManager.getCellLocation();
        cellLat = location.getLatitude();
         cellLng = location.getLongitude();
         cellAcc = location.getAccuracy();
         double cellActualLatPow = Math.pow((cellLat - ActualDisplayLat), 2);
         double cellActualLngPow = Math.pow((cellLng - ActualDisplayLng), 2);
         double combinecellPow = cellActualLatPow + cellActualLngPow;
         cellDistanceActual =  Math.sqrt(combinecellPow) * 1.1 * Math.pow(10,5);
         // set string
        String cellText = String.format("Lat:\t %f\nLong:\t %f\nAccuracy:\t %f\nDistanceFromActual:\t %fm", location.getLatitude(), location.getLongitude(), /*location.getAltitude()*/location.getAccuracy(), wifiDistanceActual);
        // Getting provider
        // Set Text
        cell.setText(cellText);
    protected void NYPNewLocation(double gpsLat, double gpsLng, double gpsAcc,
            double wifiLat, double wifiLng, double wifiAcc) {
        Log.d(TAG, "onLocationChanged with nypculation ");
        /** apply formula */
        // nypculate distance of gps from Wifi
         double gpsWifiLatPow = Math.pow((gpsLat - wifiLat), 2);
         double gpsWifiLngPow = Math.pow((gpsLng - wifiLng), 2);
         double combineGpsWifiPow = gpsWifiLatPow + gpsWifiLngPow;
         wifiDistanceGps =  Math.sqrt(combineGpsWifiPow) * 1.1 * Math.pow(10,5);
         // nypculation of accuracy of nypculated position
         nypAcc = Math.sqrt( 1/( (1/(Math.pow(gpsAcc, 2)) + (1/(Math.pow(gpsAcc, 2))) ) ) );
        //if 2 * nypAcc > wifiDistanceGps
         if((2 * nypAcc) > wifiDistanceGps)
         // if gpsAcc > wifiAcc
            if(gpsAcc > wifiAcc)
                nypLat = ( ( ( 1/(Math.pow(gpsAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (gpsLat) ) + ( ( ( 1/(Math.pow(wifiAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (wifiLat) );
                 nypLng = ( ( ( 1/(Math.pow(gpsAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (gpsLng) ) + ( ( ( 1/(Math.pow(wifiAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (wifiLng) );
            else
                nypLat = ( ( ( 1/(Math.pow(wifiAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (gpsLat) ) + ( ( ( 1/(Math.pow(gpsAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (wifiLat) );
                 nypLng = ( ( ( 1/(Math.pow(wifiAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (gpsLng) ) + ( ( ( 1/(Math.pow(gpsAcc, 2)) ) / ( ( 1/(Math.pow(gpsAcc, 2))) + ( 1/(Math.pow(wifiAcc, 2))) ) ) * (wifiLng) );
        // else
         else
         double nypActualLatPow = Math.pow((nypLat - ActualDisplayLat), 2);
         double nypActualLngPow = Math.pow((nypLng - ActualDisplayLng), 2);
         double combinenypPow = nypActualLatPow + nypActualLngPow;
         nypDistanceActual =  Math.sqrt(combinenypPow) * 1.1 * Math.pow(10,5);
        String nypText = String.format("Lat:\t %f\nLong:\t %f\nAccuracy:\t %f\nDistanceFromActual:\t %fm", nypLat, nypLng,nypAcc,nypDistanceActual);
        // set Text
        NYP.setText(nypText);
    public boolean servicesOK(){
        int isAvailable = GooglePlayServicesUtil.isGooglePlayServicesAvailable(this);
        if (isAvailable == ConnectionResult.SUCCESS) {
            return true;
        else if (GooglePlayServicesUtil.isUserRecoverableError(isAvailable)){
            Dialog dialog = GooglePlayServicesUtil.getErrorDialog(isAvailable, this, GPS_ERRORDIALOG_REQUEST);
            dialog.show();
        else{
            Toast.makeText(this,"Can't connect to Google Play services",Toast.LENGTH_SHORT).show();
        return false;}
Java:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.example.nypindoormap"
    android:versionCode="1"
    android:versionName="1.0" >
    <uses-feature  android:glEsVersion="0x00020000"
        android:required="true"/>
    <permission
        android:name="com.example.nypindoormap.permission.Map_RECEIVE"
        android:protectionLevel="signature"/>
    <uses-permission android:name="com.example.nypindoormap.permission.MAPS_RECEIVE"/>
    <uses-permission android:name="android.permission.INTERNET"/>
    <uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
    <uses-permission android:name="com.google.android.providers.gsf.permission.READ_GSERVICES"/>
    <uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
    <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
    <uses-permission android:name="android.permission.INTERNET" />
    <uses-permission android:name="android.permission.READ_PHONE_STATE" />
    <!-- Below are extra permissions for SKYHOOK...
    enables WiFi, if disabled, for the duration of a location request -->
    <uses-permission android:name="android.permission.CHANGE_WIFI_STATE" />
    <!-- used to obtain information about the WiFi environment -->
    <uses-permission android:name="android.permission.ACCESS_WIFI_STATE" />
    <uses-permission android:name="android.permission.ACCESS_COARSE_UPDATES" />
    <uses-permission android:name="android.permission.WAKE_LOCK" />
    <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE" />
        <uses-sdk
        android:minSdkVersion="16"
        android:targetSdkVersion="16" />
    <application
        android:allowBackup="true"
        android:icon="@drawable/ic_launcher"
        android:label="@string/app_name"
        android:theme="@style/AppTheme" >
        <activity
            android:name="com.example.nypindoormap.MainActivity"
            android:label="@string/app_name" >
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
        <activity
            android:name="com.example.nypindoormap.MapActivity"
            android:label="MapActivity" >
            <intent-filter>
                <action android:name="android.intent.action.MapActivity" />
                <category android:name="android.intent.category.DEFAULT" />
            </intent-filter>
        </activity>
        <meta-data android:name="com.google.android.gms.version"
    android:value="@integer/google_play_services_version" />
    </application>
</manifest>
Java:
    <permission
        <uses-sdk
    <application
        <activity
            <intent-filter>
            </intent-filter>
        </activity>
        <activity
            <intent-filter>
            </intent-filter>
        </activity>
    </application>
</manifest>
