loomer
Has anyone else noticed the new traffic widget on their phones? It allows you to put a traffic signal on your home screen, and it gets tied in with a destination you put in. It polls for traffic between where you are currently, and that location. Signal changes color (green, yellow, red) depending on the current traffic situation. I am assuming it came with the latest GMaps update? Very cool!
And in any case, it doesn't tell you where the traffic is, so you can't avoid it. Seems like just using Google Navigation is a better solution. I use it all the time on the way home from various locations, even though I obviously know how to get home.
