madspec
Hi,
Just got the S7 and I had a spare 64gb micro SD card so I installed it. Now, thing is I tranfered all the apps that let me transfer to sd card and I want to put a 128gb card in there instead.
If I copy the 64Gb card and transfer it to the new 128gb card, are the apps still going to work ? Do I have to do something special before hand or it's only drag and drop ?
Thanks !
Thanks !
That is the best way because you don't need to worry about overflowing the internal filespace.
