I just got a Note 10+ and want to use SmartSwitch to transfer data from my S7 Edge.
The problem? My S7E has an SD card. I don't have one right now for the Note 10+. If I did not set up the card for adoptable memory, then I think (I don't know) that the transfer would simply transfer main memory and I could remove the SD card from the S7E and place it in the Note 10+.
Even more important is that I remember setting up a phone with adoptable memory (I think...that was a while ago). But I don't remember going through the extra steps required to do it on the S7E. But I do see on the card files other than data files.
So how can I tell if the SD card in the S7E is set up as adoptable memory or not? That could impact the transfer process.
DL
DL
