Transformer Prime and Exhibit II or Streak 7
EwanG
My "dilemma" is that I am looking for a solution that will provide communications in a lot of places and not just be dependent on WiFi. I have had several Android tablets and both versions of the iPad at one time or another (primarily setting them up for family), and up to now have relied on a PHS-300 and a USB WiMax stick for communications for the tablet, and an Optimus V on Virgin Mobile for phone/VOIP.
So I have two solutions I am considering in a couple of weeks when I get my XMas bonus. In both cases I am planning to us T-Mobile as the provider using their new $30/month plan for 5 gigs of 3G/4G data and 100 minutes of voice, and GrooveIP to do VOIP (which is what I have used on my current phone).
Solution A is to get a Samsung Exhibit II, set it up with WiFi tethering, and then get a Transformer Prime. This will require me to carry a bag with the Transformer, and means I may sometimes have to rely on the phone where it isn't convenient to lug the Prime. On the other hand, the quad-core Prime may eventually let me do things I can't do on a dual-core machine, and it is a 10+ inch screen which should make for easier reading.
Solution B is to get a Streak 7 4G model and a stereo bluetooth headset. This would mean I'd have the tablet with me all the time (I borrowed my wife's Kindle Fire and confirmed it fits in my pants pocket), although calls might be a bit inconvenient if I don't have the headset handy. That is a dual-core tablet, and at this time, I don't know of many things in the Android market that I would need more than that to do.
Solution A runs around $800-$900, while solution B runs around $500-$600. So is Solution A worth the extra $300-$400 and the occasional inconvenience? Anything you know about any of the mentioned devices I might want to be aware of?
Thanks in advance!
