TeamPCBeach
TF101 working fine with no problems, non-rooted. Go to use it yesterday and it is stuck on the start-up screen. ASUS logo with spinning circles below it.
I did a cold boot and selected Android, same problem.
Cold boot, selected wipe data, same problem.
Tried hard reset, Android guy shows up then changes to him on his back with an exclamation point over it.
Downloaded new firmware from ASUS, installed SD card, hard reset same as above, Android guy on his back.
Renamed firmware EP_UPDATE.zip based on another thread I read same problem.
In addition the tablet won't turn off. If I turn it off, in a few seconds it turns back on, stuck at the boot screen. Let the battery drain all the way down and it finally turned off. Plugged in power and I am back to a stuck boot screen.
Any suggestions or am I bricked?
