Zingmaster
I have been dealing with the power button issue for a couple of months now. I have just found some painful work arounds to get by with since I dont really want to send it back to ASUS and then get another broke one.
I believe its the actual hardware that is messing it up. When mine started failing at first it was just occasionally it wouldnt work and then all of a sudden it was all the time. I never tried any resets or anything because I just always assumed it was a faulty button that was the issue.
If anyone knows any solutions that I may have not tried I would be gald to listen. Also I am interested in hearing if the factory reset that the above poster mentioned worked for him.
The only thing that kind of works is I downloaded an app that puts it into sleep mode for me but waking it up can be troublesome. Using the up or down volume keys will usually do the trick.
Does anyone know of any apps that you can use on an unrooted pad that can wake up a sleeping tablet or maybe I could re-map the power button to the volume button. One of the other things that is a bummer with this is I have no way to reboot the system without a functioning power button so if I want to reboot it for some reason I just have to burn the battery down.
