Hey all I am trying to figure out why I am unable to interact with the background even though my app has a transparent background? The code below was modified from the official Google Android demos here.
Here is the code I am using:
The layout:
I can interact with the FAB but when I try moving the background (which is just the standard Android home screen, I never moves.
App not running (can movie the home screen around):
Now with the transparent fab:
What can I change (or add) in order to get this to work? The goal is to have this FAB button floating regardless of what app is opened.
Java:
class FabTransformationActivity : AppCompatActivity() {
private val viewModel: FabTransformationViewModel by viewModels()
private lateinit var fab: FloatingActionButton
private var mWindowManager:/*@@psggbk@@*/WindowManager? = null
private class ItemHolder(val parent: LinearLayout, listener: View.OnClickListener) {
val image: ImageView = parent.findViewById(R.id.image)
val name: TextView = parent.findViewById(R.id.name)
init {
parent.setOnClickListener(listener)
private val menuOnClick = View.OnClickListener { v ->
val name = v.getTag(R.id.tag_name) as String
fab.isExpanded = false
override fun onCreate(savedInstanceState: Bundle?) {
super.onCreate(savedInstanceState)
var params: WindowManager.LayoutParams
setContentView(R.layout.fab_transformation_activity)
val root: CoordinatorLayout = findViewById(R.id.root)
val sheet: CircularRevealCardView = findViewById(R.id.sheet)
val menuHolders: List<ItemHolder> = listOf(
ItemHolder(findViewById(R.id.menu_1), menuOnClick),
ItemHolder(findViewById(R.id.menu_2), menuOnClick),
ItemHolder(findViewById(R.id.menu_3), menuOnClick),
ItemHolder(findViewById(R.id.menu_4), menuOnClick)
fab = findViewById(R.id.fab)
WindowCompat.setDecorFitsSystemWindows(window, false)
val fabMargin = 16
ViewCompat.setOnApplyWindowInsetsListener(root) { _, insets ->
val systemBars = insets.getInsets(WindowInsetsCompat.Type.systemBars())
fab.updateLayoutParams<CoordinatorLayout.LayoutParams> {
leftMargin = fabMargin + systemBars.left
rightMargin = fabMargin + systemBars.right
bottomMargin = fabMargin + systemBars.bottom
sheet.updateLayoutParams<CoordinatorLayout.LayoutParams> {
insets
viewModel.items.observe(this) { items ->
menuHolders.forEachIndexed { i, holder ->
if (items.size > i) {
val _item = items[i]
holder.parent.isVisible = true
holder.parent.setTag(R.id.tag_name, _item.name)
holder.name.text = _item.name
Glide.with(holder.image)
.load(_item.image)
.transform(CircleCrop())
.into(holder.image)
} else {
holder.parent.isVisible = false
fab.setOnClickListener {
fab.isExpanded = true
override fun onBackPressed() {
if (fab.isExpanded) {
} else {
super.onBackPressed()
The layout:
XML:
<androidx.coordinatorlayout.widget.CoordinatorLayout
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:app="http://schemas.android.com/apk/res-auto"
xmlns:tools="http://schemas.android.com/tools"
android:id="@+id/root"
android:layout_height="match_parent"
android:orientation="horizontal">
<!-- A FAB that expands into a sheet. -->
<com.google.android.material.floatingactionbutton.FloatingActionButton
android:id="@+id/fab"
android:layout_width="wrap_content"
android:layout_height="wrap_content"
android:layout_gravity="end|bottom"
android:layout_margin="16dp"
app:elevation="8dp"
android:contentDescription=""
app:srcCompat="@drawable/ic_add" />
A sheet that the FAB expands into.
Use CircularRevealCardView to apply circular reveal effect.
<com.google.android.material.circularreveal.cardview.CircularRevealCardView
android:id="@+id/sheet"
android:layout_width="256dp"
android:background="?attr/colorSurface"
android:visibility="invisible"
app:elevation="8dp"
app:layout_behavior="@string/fab_transformation_sheet_behavior"
tools:visibility="visible">
<LinearLayout
android:id="@+id/sheet_content"
android:orientation="vertical"
android:paddingTop="8dp"
android:paddingBottom="8dp">
<include
android:id="@+id/menu_1"
layout="@layout/menuitems" />
<include
android:id="@+id/menu_2"
<include
android:id="@+id/menu_3"
<include
android:id="@+id/menu_4"
</LinearLayout>
</com.google.android.material.circularreveal.cardview.CircularRevealCardView>
</androidx.coordinatorlayout.widget.CoordinatorLayout>
