Transparent dock?
anytyme
Member
Is there any launcher that you can make the dock transparent (about 50%) and looks like the new htc one x dock? I've spent hours trying to figure it out but it was no luck.
To get a transparent dock on Go Launcher, just go to menu>preferences>Visual Settings>Backgrounds>Dock Background>Hide Background.
Transparent =/= invisible it means you can see right through it
Ah - I saw a few responses about a completely transparent dock, so that's what I assumed you wanted. Looks like you actually wanted a semi-transparent one. Ok, give this a try -
I know it looks opaque here, but that's because it's on a solid white background.
HTH.
HTH.
thanks
