Root Triangle away!
superboy4444
Android Expert
So I think I accidentally figured out how to set the Odin mod count...my phone froze on boot animation while I was testing the cyanogenmod boot animation to see if that was a problem with cm10...btw, I think it is...and the system booted but the boot animation continued so I couldn't see anything...I held down the power button long enough which shut the phone off...It must be a hard shut down because I just tested it and if you do it there is no power down, it is just off...now when I boot, I no longer have the yellow triangle! Someone else test the hard shut down button...just hold the power button down until the phone is off...continue holding after the menu pops up
I've done this on the Rush more then a few times, sometimes I don't see the triangle but on normal reboots and when using quick boot or similar apps to get to Recovery from within the ROM it still shows the triangle for me.
This sounds about right for me on the Reverb.
