i downloaded and installed the update, i've been looking at the same android with a triangle and green ! for 25 minutes. I haven't seen any kind of progress bar either. Suggestions?
you taking it ota or through the lg updater?
and were you completely stock when you took the update? (ie. stock rom, stock recovery, stock kernel, no root)
OTA update, rooted, and as far as i know everything is stock.
i take that back i did a hard boot and booted into CWM, trying the fix in another thread.
does stock kernal include boot animation? I believe i got it back to stock recovery, and i unrooted, but update still failed but no longer locked up.
I used the oneclickroot, to unroot, realized i had CMW installed, and used the CMWbootloop_fix, got into OS. went back in and installed the stock recovery restorer (but not on V4 think that might be the problem. I can no longer boot into CMW though.
I'll mess with it later need to charge her back up. If i've gotta backup apps with TB and GoBackup, and flash back to V4 and run all updates i'll do that.
i restored to stock v6 before taking the update and the ota kept failing for me... try the lg updater if you can plug her into a windows laptop.. im starting to think the v6b update is too damn picky about what itll install over..
with the updater program it took me less than 45 minutes to download the update. get it flashed. and setup my gmail on my phone.
