Help Tricking usb to bluetooth
Joesif
I downloaded PdaNet (3G tethering) and it allows you to use USB & Bluetooth but you MUST use USB on set-up after that you can use either one. Well my issue is I don't have a usb lead from my ace to PC, so was wondering if there is anyway to bypass this part of the installation or to trick the computer to think the Bluetooth is USB. Any thoughts?
