ROMs tricore and quintetcore master-slave chipset development
derThillip
using recycled, out-dated or damaged phone chipsets as slave chips to a higher powered quadcore master chip with compatable specs to improve stability, speed and reduce lag by using the master quadcore chipset to delegate to the lower spec slave chips and control power usage where necessary only powering as much of the slave chipsets as needed. the main functions of the higher spec master chip would be delegation to slave chips as previously mentioned as well as the human interaction with the device whether its a touch screen or wireless controller for tv/media boxes.
this principle would reduce system crashes and utalize more of the potential of the higher spec chips whilst again only powering up the slave chips as much as needed at the time improving battery life of the device. ideally a full range of devices would be designed to work together covering all platforms such as mobile phones, smart watches, tablets, tv/media boxes and eventually streamlined compact desktop android pc's to run higher spec software. all platforms mentioned would have compatible built in customizable on purchase, software that communicates seemlessly together allowing you to edit, finalize and sync with each device, whenever wherever.
because of the chipset management principle not only will you be able to save money by recycling reclaimed chips and buying up outdated chips stockpiled by the manufacturers at a reduced cost, by constructing the devices in a way that allows each chip to be individually connected to the curcuit board making it possible to use single or dual core chips to make up a quadcore or octacore master or slave chip allows you to only power up as many chips as necessary, again reducing power consumption.
any extra power consumed by the proposed design principle at maximum capacity could easily be resolved by supplying thermo, kenetic or solar powered shock resistant/durable cases (where applicable) as a bundle offer when buying the whole range of devices. you could even develop thermo/kenetic/solar powered clothing that acts as a charging point when no other is available.
yes I agree it might be sometime before the bios and software would be able to utalize the potential of the principle but isn't it something to work towards?
i leave it in the technology developers capable hands! i just hope you send me the prototypes to test run.
