I am trying to install the ADT Plugin. It is not working.
Tried:
This is after Hello->Install New Software
Location: https://dl-ssl.google.com/android/eclipse (and common alternatives)
When I use http://dl-ssl.google.com/android/eclipse, I get no response
When I use https://dl-ssl.google.com/android/eclipse:
I get the resulting errors:
Multiple problems have occurred
org.eclipse.equinox.p2.core.ProvisionException
Unable to read repository at http://dl-ssl.google.com/android/eclipse/content.xml
Details Button:
https//dl-ssl.google.com/android/eclipe/content.xml.
http://dl-ddl.google.com/andriod/eclipe/content.xml
Permission denied/:connect
How do I install ADT Plugin?
I am using Java 6 instead of Java 7 per recommendation of posts elsewhere. It didn't work.
Tried:
Details Button:
