Root trouble rooting samsung admire
I turned usb bedugging on and usb mass storage and still nothing.. I keep trying and now for some reason it still wont fully root it.. now when I run run.bat.. it says device not found four times and then tries to reboot it and the phones not rebooting
I installed superuser manually and then installed an app that requires root and it the said t that the phone wasn't rooted
One of the problems that caused the root process to act funny is the program " Droid Explorer " if you have it installed try to uninstall it or stop its service from windows service manager.
also try to start the rooting process as an administrative right.
removing the sd card was reported by some users that it might have part in solving it.
Also make sure you have the Samsung Admire driver installed in your PC get it from here
http://www.samsung.com/us/mobile/cell-phones/SCH-R720ZAAMTR
