J
jamistasty
Guest
Hi all, I'm pretty desperate for a fix, so I hope you can direct me to some help.
I backed up all my app data on Helium today. I checked after that it recognized all my backed up apps and gave the option to restore all of them. After I factory reset, it now says it can't find them. I see all the folders on the SD card, but they're not recognized. My SD card was removed from the phone during the restore, all my photos on the card are fine, so I don't know what happened.
Most people seem to fix it with this method: 1. Start Helium 2. pick any "dummy app" to create a backup from 3. Exit Helium 4. Check where it placed the backup files, and which files those are (a backup consists of multiple files) 5. Copy your backup files to that location 6. Check if for each app there are all the files you've checked above1 7. Start Helium again, it now should find the backups 8. Restore whatever you wanted to restore
But it still only sees the recently backed up apps, not the many others from before the reset I've pasted there. What is different about my previously backed up apps that it is not recognizing? Please help, I'm so confused and I don't have any other backups.
This is my first time trying to back up my app data, and I'm super frustrated that this app that seemed so useful completely failed me.
Please PLEASE tell me there's something I can do to fix this! I'll try anything. Oh and also I have a galaxy s5, if that helps.
Thank you for reading, any help is super appreciated.
