Help Trouble with Clean Master
  • Thread starter Thread starter Trouble with Clean Master
  • Start date Start date
T
Guest
Will Clean Master force quit other applications?
Please check out the following video:
Here are more detailed information:
Depended on its “Battery Saver” Mode, Clean Master can easily guide users to authorize their accessibility features on smartphones. This aims Clean Master to observe your actions and retrieve window contents. While users switch on the low power mode, the accessibility feature is being activated as well. As mimicking users’ manipulation, Clean Master is able to FORCE STOP applications which are not on the whitelist. This indicates that users will no longer receive any push notification from blocked applications unless they activate them manually within launcher. Meanwhile, users may miss important push notifications from those misbehaving applications.
We know. The moment someone mentions clean master, the reply would be to tell the OP to uninstall it. Sometimes never mind that it wasn't the complain to begin with. And force closed apps and missed notifications are the least of your worries if you regularly use clean master.
