markdoc
Android Expert
I'm having problems with my contacts. For some unknown reason, the Primary number that I set keeps changing. At first I thought it was me. It's not. I set the primary by long pressing the number. (and choosing primary number) Then, sometime later, when I use a widget to call, I get one of the other numbers. I go back to the contact and the primary number has changed from "Work" to "Mobile" or from one mobile to another. This has happened with different widgets. Any ideas would be helpful. Thanks for listening.
