Trouble with group texts
I have tried both multiple times. It freezes and says "Performing critical backups ....".
It also
....will not read my group contacts properly i.e. 22 when group has 34.
....Shows 101 delivered out of a group of 122.
122 in a group text?
I'm not sure any messaging app will handle that many at once
I have tried other group apps and none will do what tie one I use does! Looks like I may have to give up some features and try another one!
Have you tried using a voip app like Dingtone?
Or it would be much more simple if all the people you were texting had Telegram.
That would be the best solution in my opinion.
