I'm using the bluetooth of an android phone to send some data (strings) to an arduino with bluetooth device.
All works like charm... but I can only send 325 strings!!! (each string only contains 2 positive int numbers).
After this, at the logcat of eclipse, appears me this message: "rfc_setup_rx_bufout of buffer: rfc_setup_rx_bufout of buffer: Out of Buffers" each time that the android tries to send a new data.
I can't close the bluetoothsocket and reopen it (or connect) during the application cause I need to send data very fast for my purpose(about 100-200 ms one after another) and there's no time for that. How can I "clear" the buffer? Is it really the problem with the buffer??
Part of the code I'm ussing this:
The "message" in message.getBytes(); is actually the string that I'm sending.
Another thing: I'm ussing an array (byte[] msgBuffer). Is there anyway I can make a "loop" to get to the [0] or [1] index after sending the data so this string will never be full cause I would only use 2 values.
Or the problem is with an internal buffer of my phone (samsung GT-I5500) and no with the code?
A will really apreciate any help cause I'm stuck in this.
Code:
private BluetoothSocket btSocket = null;
try {
btSocket = device.createRfcommSocketToServiceRecord(MY_UUID);
} catch (IOException e) {
try {
outStream = btSocket.getOutputStream();
Log.e(TAG, "ON RESUME: Output stream creation failed.", e);
byte[] msgBuffer = message.getBytes();
try {
outStream.write(msgBuffer);
Log.e(TAG, "ON RESUME: Exception during write.", e);
