TRRS Jack Polarity
I've owned my X10 for about two months now and I'm loving it to death. I recently bought a set of Razer Moray + earbuds because I'm not too fond of the included headset. I thought they would work as they have a TRRS connector and the phone has a TRRS jack. Just to my luck, they're not compatible. So my question is, what are the polarities of the TRRS jack inside the phone? Is it not a standard to have ground as 'this' band and microphone as 'that' band? Alternative earbuds?
Some folks have said that "other" earphones dont work on the X10 but I have used ipod one and until the "accident" used the ones that came with my old LG Renoir.
No idea about your issue though as, as you stated the "+" "-" are the same on all head phones?
Try using the SE mic and plugging your earphones into that insted of direct into the phone but that should not be a cause as I plug headphones straight into the 3.5mm jack and they work fine???
