Failure. Ok I rooted using Visionary. Everything works great but my camera will not open so I thought I would flash with 2.2 and start over. See if that was the issue. I did a hard reset of the system and the phone is still rooted which I understand. My problem is I can't seem to figure out how to successfully flash. I downloaded both RSD Lite and SBF 2.2. I have attached my Droid X to my PC and checked debugging. I have opened the Droid X window on my PC which only shows my SD Card. I then go to my folder holding both RSD Lite and 2.2. I click on RSD Lite and open it and install it. After that I'm lost. Nothing happens. What am I suppose to do move forward. Thanks
