Trying to use ad-hoc on tf101
Mako 230
SOLVED I'm trying to tether to my phone's adhoc connection since my carrier recently disabled foxfi. From what I've read adhoc used to work natively with honeycomb but was disabled in ics. My thinking is this. If this is true I could install a custom honeycomb rom. Is anyone still running a hc rom and if so could you confirm an adhoc tethering capability? I'm not sure but it may also have worked with the first ics versions and if that's the case I could try that too. Does anyone have adhoc working on there tf101?
Thanks
Tried all sorts of things but what worked was simply enabling wpa security to barnacle.
