richard.tufty
Does anyone else find that TuneIn Radio Pro buffers every 30s? When I use it on my Evo over 3G it will buffer for 1s every 30s without fail. Looking at the screen when it's buffering, it seems that it needs the buffer to be 100% full the whole time, since it shows 90% when it pauses to fill up.
I thought the purpose of a buffer was so that it could be used whilst there was a drop in data, and then it fills up in the background when the data connection is back. TuneIn doesn't appear to use it this way!
I have tried looking for an option to increase buffer size without luck, is there such an option that anyone has found? Or maybe a "minimum buffer level before pausing" setting?
Any help appreciated,
Richard
Richard
