This one's easy: Press the volume down, then tap the bell symbol that is on the left side of the volume slider. It turns to the vibrate symbol. To switch back, repeat, tapping the vibrate symbol. Note that there is no silent mode, but by using the sound filter, you can select "none".
Be sure to read all the tips in the Help; search help for "vibrate" and you will see them.
