Turn off 3G data and wifi during call
Hi,
I have been searching for an app that turns off 3G data and wifi during a phone call. Ideally, the app will also restore the services to their previous state after you hang up.
I have been looking through Google Play to no avail. Any suggestions?
Cheers,
Andrew
Hi,
Cheers,
Andrew
Search for "EasyProfiles Pro" in the Google Play store
Thank you everyone. Googling your suggestions lead me to a bunch of task/trigger apps.
Tasker seems to be the most flexible but may be a little overkill for my needs.
I am going to try Easy Profiles and AutomateIt which has the feature sets I need.
Cheers,
Andrew
Hi,
Cheers,
Andrew
Hello Andrew,
please check Talk Intact app on Google Play. I have developed this app recently and it does exactly what you need. It turns off Mobile Data, Wi-Fi, Bluetooth and Data Sync protocols during a phone call. Then it restores the protocols back automatically.
You can select which protocols to control (turn on/off).
It can work in two modes:
Mode 1.
Talk Intact turns off selected protocols each time the phone comes close to your ear.
Then it turns protocols on back each time the phone is moved away from a head. In this mode your phone remains fully functional during a call. E.g. you can read emails, use messengers, surf the web while talking (e.g. using speaker).
Mode 2:
Talk Intact turns off selected protocols first time the phone comes close to your ear.
Then the app turns protocols on after the call is ended. In this mode more battery power saved.
Please look for "Talk Intact" on Google Play or copy the part of url below:
play.google.com/store/apps/details?id=com.talkintact.tiapp
Best regards,
Georgy
