If you really mean to SILENCE the phone at certain times instead of turning it off, Silent Time Lite is a free app that does just that. You can set up a schedule for the phone to be silenced or silence it manually and manually turn the ringer back on. You can set up exceptions that allow certain people to ring through when the phone is silent for certain events. For example, you can allow someone to call when you have the program set up to silence the phone overnight, but they can't call through when at a meeting.Is there an application/widget that will automatically turn the phone on or off at a certain time? Thanks,
There is an app but your phone neds to be rooted and plugged in the charger for it to work. The app is No Moar Powah! I use it every night, my phone is plugged in and set to start up 5 min before the alarm gets off. It loads automatically the alarm time, and sets the startup 5 min before but you can manually st the startup time.
