Sakib
DEOXEDING
First, The Easy Way !
The Titanium Backup Way !
1.Download TB (Titanium backup)
2.Open TB, Give it Root Permissions
3.Press Options, More
4.Press Undo sys Dalvik integration
And Wait fr a Minute and It will ask you for the last Confirmation !!
And After you Press Yes It will Reboot and You Phone Will be Deodexed !!
*Note: This only Works on Some ROMs
So You might have to look at the 2nd Post !
There is a Like, Thanks Button Too !
