Help [TUTORIAL] How to reset your Android to default settings
matrix69
1. Power off phone
2. Press and hold Menu Button ( middle ) + power on for at least 10 seconds
3. Android System Recovery Mode Appear
4. There are 4 options
  • reboot system now​
  • apply sdcard:update.zip​
  • wipe data/factory reset​
  • wipe cache partition ​
5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode
6. After the process done, phone will reboot.
I hope I helped you.
1. Power off phone
