D
Deleted User
Guest
This lines i just made for my gamerroms but decided to share them
Be aware that these may or may not be the full tweaks but current to date ill add anymore once i have developed more
# Mainkeys Properties
"qemu.hw.mainkeys=1" <--- Allows you to enable nav bar on screen 0=Enable 1=Disable
* Firewall Properties
"persist.firewall.support.nat=1" <--This allows support via ip to tell the router your device support firewall functionality
"ro.firewall_enable=1" <-- this tells the os and router that you have firewall protection on.
"ro.firewall.upnp_enable=1" <--- Allows The firewall to support and protect upnp connections
"ro.firewall.nat_enable=1" <---this will tell the os to enable nat type support and tell the router to start Nat Type filter the options enabled on above
