[Tweeks] & Bugs with the LG G2, and how to fix them
bakkiz
I got a few bugs... I study industrial design, so I'll try to be as picky as I can ;)
I know there is a similar thread on this, I was going to post there, but it got a little out of hand and I made an entirely new concept.
I'll try to update the first post with your suggestions and fixes for easy access.
FEATURES MISSED OR NOT WORKING PROPERLY
  • Knock on feature - Of course there is the knock on feature. Maybe if they started calling it the triple knock feature, there wouldn't be such displeasure.
    Fix: Download Gravity Screen Off that uses gravity and acceleration to lock your screen.
  • Knock off feature - If you have a full home screen you have to reach for the status bar to knock off the screen.
    Fix: Root --> install the Xposed framework --> install the G2 Xplosed app --> set home button long press to lock screen
  • Long press on buttons to add functionality - Both the hard buttons and the navigation bar should have options to edit the action if you long press them.
    Fix: Root --> install the Xposed framework --> install the G2 Xplosed app --> buy premium (1USD)
  • Disable the power sounds - I want to be able to disable the power on and off sounds.
    Fix: Root --> install the FX File Explorer --> replace the "/system/media/audio/PowerOn.ogg" and "PowerOff.ogg"
  • Edit the shortcut menu - I want to be able to edit the icons in the shortcut menu when you swipe from the bottom of your screen.
  • Font support - The font I bought on my old Samsung does not show up in the screen settings font list.
  • 10 by 10 grid - If you could make widgets half by half the size of a grid square it would be great. If widgets doesn't support this partitioning yet, it would add the possibility for adding your own margins and also leave blank spots for knocking of the screen.
  • Audio profiles and silent modes - When you turn the sound volume all the way down, past vibration you get another silence mode than if you press the "Silent mode" button. The difference is that media volume also is turned down if you use the silence mode button. It's confusing that the silent mode button doesn't do the same thing as turning the volume all the way down? The way to distinguish between these two isn't intuitive, and I don't think most users would research this on their own, I would join these two different ways of turning off the sound into one. If I chose to play any media I know that it's gonna make noise so I don't need a warning, the exception is when a web page plays audio, then I would need a warning.
  • Automatic light calibration - The automatic light intensity don't seem to work very well. When I turn on "Auto" the scale seem to change to exponentially increasing, but the light doesn't react to outside light intenisty.
  • Unnecessary text on home screen icons - I want a setting to remove the text under my home screen icons. I don't need the text to understand the phone icon opens the phone, I want my icons lean and clean like it is on other phones. The whole point with having icons is that you don't need any text. My brain also processes symbols/icons faster than text.
  • Unnecessary "Swipe to unlock" text - The "Swipe to unlock"-text on the lock screen is really annoying and litters the otherwise clean and fancy effects and wallpaper. You don't need instructions on intuitive features. At worst I only need it to be there the first three times I swipe to unlock, then I remember it. Samsung solves this problem with a checkbox to show the text in the screen settings.
    Fix: Root --> open "system/framework/framework-res.apk" in a zip-program --> open resources.arsc in a hex-editor and search for the text in you language --> change the very first byte of the phrase to hex "00" and all the others to "FF" --> save and reboot.
NOTIFICATIONS SCREEN AND QUICK SETTINGS
  • Wrap quick setting icons - The quick-settings icons should have the choice to be wrapped to a new line instead of scrolling to the side. It is important that it is quick, and I want to have fixed positions so that I knows exactly where it is without reading or analysing symbols.
  • Buttons for silence - In the quick settings there is a button for Audio profiles (Sound, vibrate and silence) and a quiet icon. I addressed the problem with two silent modes, and there isn't need for more than one button. However if you are in a meeting and want to turn the sound to completely silent you have to press past the vibration setting, and it makes a little vibration that makes a possible embarrassing sound. If you instead change the order of the vibration icon so that the order is "sound" "silent" "vibration" they would fix this problem.
  • Volume slider - The volume slider takes a whole lot of space and should be switched out with a button to access the settings. You already have the hard buttons on the back of the phone, no point in wasting anymore place in the notifications screen.
  • Brightness slider - The brightness slider wastes too much space. Most users just set it to Auto and forget about it anyways. It could be replace with a button you could turn off. The slider also doesn't work well. When you try to turn up the volume to ex. 90% after your phone has been in silent mode, you first get an unnecessary prompt to ensure that you want to turn it up. And then it only turns up to the volume you had before the silent mode, not 90%.
  • Edit key - I would want to remove the edit key on the Quick-settings and maybe the QSlide in the menu itself, and rather place it among the other settings. The notification screen is a completed solution I want to perfect for my needs in the main settings. I know that it could be handy to have the edit key near by the first time you get your phone, but if the edit keys are gonna be part of the menu forever the whole notification screen seems like it's a under construction and never completed.
  • Unnecessary text on settings icons - I want a setting to remove the text under my settings icons. I want my icons lean and clean. The whole point with having icons is that you don't need any text. My brain also processes symbols/icons faster than text.
APPS
  • Camera - It should be possible to set the path to save images. It should also be possible to turn off the camera shutter sound, I know some countries require a shutter sound because of privacy laws but you can easily bypass this by setting the phone in silent mode or downloading a new camera app.
  • Messages app - The customization of the messages is neat, but the possibilities are a bit limited. Also if you delete a message thread you also delete the custom theme set for that contact.
  • Music player - In the Music player the only thing showing which file is currently being played is a little animation to the right for the song title, it's annoying to move you eyes every time you want to see which song is playing. Why not do it the usual way by changing the color of the song title, in addition to the little animation?
    Sort by artist name also in album-section. I often don't remember all the names of the albums, but the Artist I always remember.
    This way you also get all the albums of one artist nearby each other.
GRAPHIC DESIGN
  • Icons and colors - The graphic design of the icons are terrible, mostly because of the blue color. Color choice might seem arbitrary, but it's not, and I don't think they have given it much thought.
    Fix: Root --> install BusyBox --> install MetaMorph or something.
  • Navigation bar colors - I want to be able to change the color, glow color and size of the navigation bar.
TRANSLATION MISTAKES: (This is for LG developers, so you can fix this in the next updates)
Norwegian translation:
  • When the battery is fully charged and you get a notification there is a typo, it should be "Vennligst koble fra laderen for
Great job on the list, nice to see it in one post. A few of the items might vary slightly by variant (i.e. there is no brightness slider on vzw model, etc) but not major differences. Thanks for posting that up.
Some apps show the error "This app is incompatible with your device"
Fix: ROOT >> Install Xposed Framework >> buy premium (1USD)
Open The Xposed Framework app >> Click Download > All Apps In Play Store
Download and install that listing >> Finally reboot.
Is anyone else out there having problems with the screen flickering??? This is my second LG g2. I had to return my first one because of that issue and some other problems ie: overheating, phone turning back on constantly after I double tap to turn it off, etc, etc.😟 This phone was flickering too until I downloaded the latest update, but I think l just saw it slightly flicker again at the top of the screen
(But not as bad as my first phone)😬😱
My phone started flickering. Small changes in illumination level very rapidly. I've returned it for a replacement. Hopefully the problem is rare. On another site I read last evening someone apparently fixed the issue by manipulating the aspect ratio setting of their device. I don't have one at the moment so I don't know where that setting is...
Have you solved your problem?
Im now on my 3rd lg g2 phone and no screen flickering problem thus far (fingers crossed)😕😟
ABC76.
Thank you for the response. If this was a uniform issue, I would expect a lot of buzz about this. There are some posts here and there on the web.
Question: have you been using a thin-film screen protector?
My screen is freaking out. The knock on feature quit all together, it starts firing off random letters while I'm trying to text, the touch screen stops responding or won't scroll when on a website or facebook, it will flash from one thing to the next if you are in the settings menu.....
I have a replacement on order through Sprint but I am very discouraged by all the posts I see about people having the same issues and on their third or fourth replacements! On the other hand my sister, niece and her fianc
It's just a faulty unit, keep calm :)
I've seen some tests and posts about touch panel - digitizer - issues on youtube and forums and it seems that there are only some units affected by this issue.
Good luck with the screen issues cause i'm on my 4th G2 and my 5th one is in the mail. I've tried numerous things to resolve these issues. I believe its something I'm downloading (even though everything I download is from the playstore). I think I'm just cursed with cellphones. 😒😞😣😭😢😥😧😦😟😩😫😕
With my replacement, I've got mine set on Automatic and 50% (although I've tried 60%). If I just linger in the Display menu, illumination level will change as a function of if I hold my hand over the ambient light sensor, or tilt my screen to/away from the light... and it does so in steps.
The ambient light sensor must adjust screen illumination down if the room darkens, as a function of the "Automatic" setting.
But then, I think there is a component that is manipulating the illumination intensity as a function of what is being displayed on the screen, per that post below.
I'm just throwing this out: for me then the question becomes, is it the Automatic Setting and Ambient Light Level sensor, or perhaps the Dynamic Contrast Based on Content function at root cause?
If the former, you might be able to turn off Automatic and see if that fixes it. If not, if the to test the latter, perhaps this happens on pages where the contrast of displayed content is changing - can you find a page or display like that were you can force it to flicker? Maybe then I can try mine to see if I see the same effect I experienced with the first unit I had and experiment more.
I am seeing this effect in Dolphin browser when reading messages. Might be influenced by the room I'm in with respect existing lighting...
With respect to a setting to adjust this... I Just turned Automatic off and it seems better.
Hmm I don't agree with the knock on complaint in the OP. I haven't had issues with it, a lot of the time its just user error. I've seen people complain about it when it turns out they're just tapping too slow.
I'm having issues with the screen effect not working anymore. I don't know if i changed some kind of settings that caused this but it was working initially, now it just slowly dims off.
Go to MENU > SYSTEM SETTINGS > DISPLAY > SCREEN > SCREEN-OFF EFFECT.
I did. I have tried all three and they're not working anymore. I installed xposed framework and xblast. With it i can get vertical crt to work and if I click any other option the black hole effect works but not the "old tv style".. I wonder if it's xposed all together that messed it up..
EDIT: Just removed all settings in gravity box and disabled the module, now it's working again. Hmmm
Kinda sucks because I really like centering my clock with gravity box because xblast doesn't hide am/pm even when selected. It also removes the battery percentage when the clock is centered. Oh well guess it'll have to do with xthemer.
I have used a third party camera app and it still makes the shutter sound unfortunately. I dont think it can be removed.
