Tweet from Notification Panel
I know you guys hate when people say this, but I really want a feature the iPhone has. The "tap to tweet" option in the notifications panel is so convenient, and I can't believe I can't find anything like it. The only app that came close to it was QuickTweetPro. But that's listed as an ongoing app and the icon never goes away from the notifications bar.
Are there any apps that will work as a quick tweet option, instead of opening up an entire twitter application? I just want to be able to use pie controls to select a quick tweet option, tweet from a popup window, and then go back to what i was doing without ever leaving the app I was in.
You guys know of anything like that?
Notishare is alright. The only problem I have with it is that it's invisible notification puts an awkward black space between my other notification icons. And when I tweet it puts "via notishare" at the end of whatever I write.
That might have worked. Good idea. I actually downloaded Plume and used one of its activities. It brings up a "new tweet" widget at anytime on any app. Exactly what I was looking for. All I have to do is hold down the home button.
Thanks guys. I'm just really surprised no one else has asked about this before
