Twitter Authentication Error
Hello, I'm having a problem with the twitter apps of my Samsung i5700, I've looked all over the web and I can't seem to find a solution. I'm hoping you have some idea of what the problem is and how to solve it:
Everytime I try to log in into my twitter account, some kind of authentication error occurs, I've tried several Twitter clients (Android stock, Twydroid, Twitcaster...), and it's always the same error. I've deleted cache, made a factory reset, and even reinstall Android all over again, but the problem persists. I've tried on Android 1.5 and Samdroid 2.1, and it's always the same deal. I've managed to get a log of several log in tries with the andoid stock app for Twitter, and here it is:
Code:
07-31 18:09:52.503 I/PUSH Event( 1971): MotionEvent : QueuedEvent{44c01320 MotionEvent{44b751d8 action=0 x=93.706245 y=230.51874 pressure=0.421875 size=0.0}}
07-31 18:09:52.598 I/PUSH Event( 1971): MotionEvent : QueuedEvent{44b76a50 MotionEvent{44b771d0 action=1 x=94.703125 y=228.52292 pressure=0.328125 size=0.0}}
07-31 18:09:52.793 D/dalvikvm( 3989): threadid=3: bogus mon 1+0>0; adjusting
07-31 18:09:53.623 W/DefaultRequestDirector( 3989): Authentication error: Unable to respond to any of these challenges: {}
07-31 18:09:53.633 I/NotificationService( 1971): enqueueToast pkg=com.twitter.android callback=android.app.ITransientNotification$Stub$Proxy@4466d5d8 duration=1
07-31 18:09:53.658 D/dalvikvm( 3989): threadid=19 wakeup: interrupted
07-31 18:09:53.658 D/dalvikvm( 3989): threadid=21 wakeup: interrupted
07-31 18:09:53.663 W/InputManagerService( 1971): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4465bb30
07-31 18:09:54.178 E/libs3c2drender( 1971): int S3c2DRender::DoG2D(unsigned int, s3c_img*, s3c_rect*, unsigned int, s3c_img*, s3c_rect*, int, int)::S3C_G2D_ROTATOR_18176 fail
07-31 18:09:54.178 W/copybit ( 1971): stretch_copybit::run_render fail
07-31 18:09:54.223 I/PUSH Event( 1971): MotionEvent : QueuedEvent{44b7cc10 MotionEvent{44b7c898 action=0 x=93.706245 y=229.52083 pressure=0.390625 size=0.0}}
07-31 18:09:54.323 I/PUSH Event( 1971): MotionEvent : QueuedEvent{44b7ec38 MotionEvent{44b7e8c0 action=1 x=92.70937 y=231.51666 pressure=0.359375 size=0.0}}
07-31 18:09:54.763 D/dalvikvm( 1971): GC freed 42420 objects / 2601104 bytes in 275ms
07-31 18:09:55.883 W/DefaultRequestDirector( 3989): Authentication error: Unable to respond to any of these challenges: {}
07-31 18:09:55.933 I/NotificationService( 1971): enqueueToast pkg=com.twitter.android callback=android.app.ITransientNotification$Stub$Proxy@448f94e0 duration=1
07-31 18:09:55.973 D/dalvikvm( 3989): threadid=19 wakeup: interrupted
07-31 18:09:55.988 W/InputManagerService( 1971): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@448dde28
07-31 18:09:56.003 D/dalvikvm( 3989): threadid=21 wakeup: interrupted
07-31 18:09:56.503 E/libs3c2drender( 1971): int S3c2DRender::DoG2D(unsigned int, s3c_img*, s3c_rect*, unsigned int, s3c_img*, s3c_rect*, int, int)::S3C_G2D_ROTATOR_18176 fail
07-31 18:09:56.503 W/copybit ( 1971): stretch_copybit::run_render fail
07-31 18:09:56.708 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:56.713 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:56.823 D/dalvikvm( 2137): GC freed 625 objects / 59008 bytes in 92ms
07-31 18:09:56.833 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:56.833 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:57.318 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:57.318 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:57.438 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:57.438 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:57.593 D/dalvikvm( 3989): GC freed 6972 objects / 483472 bytes in 95ms
07-31 18:09:58.068 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:58.073 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:58.188 D/WindowManager( 1971): @@ RawInputEvent keycode = 4cur result = 1
07-31 18:09:58.188 D/WindowManager( 1971): interceptKeyTq return -> 1
07-31 18:09:58.608 W/DefaultRequestDirector( 3989): Authentication error: Unable to respond to any of these challenges: {oauth=WWW-Authenticate: OAuth realm="https://api.twitter.com"}
07-31 18:09:58.633 D/dalvikvm( 3989): threadid=19 wakeup: interrupted
07-31 18:09:58.633 D/dalvikvm( 3989): threadid=23 wakeup: interrupted
07-31 18:09:58.893 I/PUSH Event( 1971): MotionEvent : QueuedEvent{44b7e140 MotionEvent{44b60798 action=0 x=153.51875 y=455.05 pressure=0.375 size=0.0}}
07-31 18:09:58.973 I/PUSH Event( 1971): MotionEvent : QueuedEvent{449a5850 MotionEvent{44b5e7d0 action=1 x=151.525 y=456.0479 pressure=0.359375 size=0.0}}
You can see several "Authentication error: Unable to respond to any of these challenges: {..." on the log, corresponding to my log in tries.
Anyone has any idea what the problem could be? I'd really apreciate your help.
Tell me if you need more information.
Thanks beforehand!
