Twitter Authorization on Transformer
Martin J
Has anyone else tried to use a Twitter app and found it won't authorize on the Transformer?
Both Plume (beta) and TweetComb, both of which are supposed to be well-suited to Honeycomb produce the same error:
"The authorization link between Twitter.com and Plume could not be created. Please try again to add your Twitter account. Possibilities: No connection, wrong phone time/date or you did not authorize Plume."
Password/username are correct as is the time, there's a good active data connection and the official Twitter app works just fine.
Ideas?
I registered on this forum after seeing your post....im having the exact same problem.
1. I'm actually on the Acer A500 Iconia, not the Transformer.
2. I have multiple accounts and have tried them all on Plume and Tweetcomb.
3. The official twitter app works fine.
4. No_u's response was the least necessary thing ever, maybe someone else has had this problem and has a fix...
Actually, it wasn't. It shows that it's not everyone who's affected.
Still helpful, kudos dude.
OP- I emailed tweetcomb dev and got an answer- make sure your time zone settings are correct....this worked for me. good luck!
