Twitter doesn't work in my phone
Laurytora
Hi! I have a Samsung Ace since August. This days I tried to connect Twitter but I recieved a message wich say that i need to try again... I tried a lot of times but it's impossible... What can I do??
Welcome to the forums laurytora, glad to have you aboard :)
Hopefully I can try and assist you with the issues that you are having today.
I would first try to uninstall the app and reinstall it. Otherwise try preforming a battery reboot by removing the battery and re inserting it, then restarting your device.
Hope this helps and thanks for joining :D
Welcome aboard.
Hopefully DC suggestions will work for you.
Thanks for joining.
Happy Holidays! :santaclaus:
