Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
Here's what you need to do. Uninstall all the applications that you don't need or use on a daily basis. Most likely this problem is caused by either a "rogue" or "incompatible" installed application. Hopefully you might catch the culprit in doing so. However, if problem persist.. you would have to "reset" the device.
BTW, Hello and welcome aboard. Here's hoping you'll find this place helpful. ☜
