Apps Two Android emulators in Eclipse
c2tarun
Hi friends,
Is there any way to run two android emulators in eclipse with both the emulators of different versions? like one of 2.3 other of 4??
Hi friends,
Yes it is possible...
you have to create multiple AVDs of different OS versions then launch the project with the AVD then go back to eclipse select the project folder right click and select project build target then launch it again and it will launch 2 builds of different os versions...
and here is a picture of the live wallpaper i made running on both...
Thanks for the reply :) I actually figured out the issue, just forgot to mention it here :( sorry for that.
