Help Two Anti virus apps - Ones draining batteries - Which to keep or recommend
Hi
I have an Acer Tablet with McAfee per-installed and CM security installed by me. Both or one is draining the batteries. Which one should I keep and remove or which anti virus app would you recommend?
Personally I don't recommend any anti-virus but if you're gonna keep one, I'd get rid of CM. It has a really bad reputation.
Which is draining your battery though?
