Two Data Manager's?
mike2874
I'm totally new to Droid phones so I need all the advice I can get. I just bought a used Incredible2 to use with Page Plus but since it's data plan is very limited I need to closely monitor things.
I installed 3G Watchdog Pro and so far I really it but can you also have My Data Manager installed at the same time I like it's ability to show what individual apps are doing?
I used to use 3G Watchdog but found that just lately it has proved inaccurate in reporting data usage and so switched to My Data Manager which seems more reliable.
There is no reason that you cannot run both of them together. I also heve TrafficStats Lite installed.
Hope this helps. :D
Yes that helps a lot thanks!
I had also wanted to install Juice Defender since it's rated pretty high but now I'm seeing some say it hurts more than it helps what gives?
