Accessories Two fully charged batteries or extended battery?
That's impressive life with that heavy use and also with background, auto-sync on. How big is the capacity of extended battery? Does it make D2 thicker and require different back cover?
The battery comes with a new back cover but the thinkness it adds isn't bad at all. I was even able to use the same case I originally had after installing the extended battery.
I'm finding that if I am playing my music player it drains the battery faster than anything else. By this, I mean the installed music player with my .mp3s. Is there any way to tweak any settings for that? Are some music players less battery hogs than others?
The battery is BP7X 3.7V 1860 mAh.. It is from Verizon. It comes with a different battery door and it only makes the phone less than a centimeter thicker only at the battery door..
Definitely a must buy if you are a Heavy user. This beats 2 batteries any day. I would not want to put up with the hassle of having to switch batteries and having to charge 2 batteries.
Extended Battery all the way man :cool:
Thank you man I think I'm just going to go with the extended battery
and then carrie a extra one around just in case=) thanks guys!!
If you are even considering a second battery, can I suggest you go with an extended batter and the stock battery?
I just got the extended battery and will probably fix/glue a piece of metal to shore up the stock battery so it will fit nicely with the extended battery backing. The phone runs a little warm and I want to make sure the heat sink properties is still there.
